Folding - Adjustable height table
  • Folding - Adjustable height table
    I made this table for different purpose but, I will not tell you which one because you will laugh at me....
    But, while working on it in the garage, I thought that I can use it also as an adjustable height table for the Drill press, table saw, router table and alike to support long boards.
    The base is two frames, M&T (made with the "rolling tenon jig" on the table saw), connected with bolts as an X...the top can be any plywood, melamine or whatever.
    If I would make it for the shop, I would make it from more "massive" wood, say 2 x 4" and wider footprint so I can use it also as a low (or high) assembly table
    Regards
    niki
    Re: Folding - Adjustable height table
      Very Cool. I like the micro height adjustment knob a lot.
        that is very nice i like it and will make one to use at work as a print table when i'm standing or i can lower it when i want to sit at the table
        thanks
          Your ideas are always good, don't you ever lose that. Your table is great like the rest of your stuff....
            Thank you so much for your kind comments
            I'm so glad that you like it...
            Regards
            niki
              Niki, you've done it again! I'll get to building this hopefully next week. I've been needing something to be an outfeed table for the TS, but I don't want to dedicate the space to one. This table will serve a lot of purpose in the shop. Thank you so much!!
