Hold-down clamps - simple, fast and cheap...
  • Hold-down clamps - simple, fast and cheap...
    Good day
    I'm not sure that you will find much interest but for the "maybe", I'm posting it.
    I was looking for something easy and fast that I can move quickly from one table or jig to another...
    All the "clamp" is actually a piece of scrape that I just drill a hole for the "bolt".
    You can make it at any length, width and thickness...just stick two pieces of sanding paper (with white glue) and you are done.
    Too much talking, isn't it...
    Regards
    niki
    Re: Hold-down clamps - simple, fast and cheap...
      Another clever idea! I wish they still made Workmates like they used to, but I can't find the old style anywhere. Fortunately, you posted a very good Workmate replacement so I'll be putting it together with these clamps in mind. Thanks again!!
        Thank you VASandy
        I just went to the garage and took those pics...
        To make them even more versatile, I just took them to the router table and made a slot that gives me the possibility to "play" with the length...
        On the last pic, you can see that I use them also on the DP table but you can use them on....your imagination is the limit...
        Regards
        niki
ID:	615894Click image for larger version
ID:	615895Click image for larger version
          Niki - how do come up with the stuff??? I wish I was half that creative. Thanks again for some great ideas!
