how thin is thin
  • how thin is thin
    with a 4330 planer how thin can we go.... Can I get to 1/8 of an inch?thick ???
    §m€llŸ™
    Re: how thin is thin
    I believe 1/8 is the min but regardless the lowest setting on the planer should be its limit. It will be listed in the manual and specs on the website - I am to lazy to look it right now.
      Actually, with a sled you can go even thinner, but that's not an easy task. Most only go down to 1/8".
      If at first you don't succeed, try reading the owners manual.
        Sometimes if you go thinner than 1/8", the wood will blow apart, especially with highly figured wood.
        Joe Spear
