Cheap "Grip clamp" repair and improvement
  • Cheap "Grip clamp" repair and improvement
    Good day
    I bought those cheap grip clamps. After some time I noticed that they are not "gripping" but sliding back. Another problem was, the handle pin housing breaking.
    For the pin housing, I drilled hole and replaced the pin with screw (bolt) washers and nut.
    I solved the sliding problem by grinding the clamp bar narrow sides with # 40 to make them rough.
    It was such a good repair, that I made it on all my grip clamps, even the good ones.
    Regards
    niki
    Re: Cheap "Grip clamp" repair and improvement
    Good idea! I've got a small collection of those clamps. I'll save your repair idea for when they start to fail. Thanks for all the good ideas and their clear presentation.
    Dick
      Superb, Niki! I've got a bunch of these clamps, and you're right..they definitely don't clamp as well as they used to. I always thought it was a problem of the clamp itself not being able to handle a good amount of pressure. Then I recently got a couple new ones (6" Irwins on sale 2for1 somewhere), and the new ones have more clamping pressure than the old ones. Thanks for posting this so clearly.
