Trunion bolts
  • Trunion bolts
    The back of my saw blade is 1/64 out of line with the front.
    I have loosened the trunion bolts(exept for the middle one on the back which has a different size bolt) and they were all very easy to loosen.
    I might have been able to do them with my fingers. How tight should they be?
    I have to find the size of the middle bolt now and loosen it.
    Re: Trunion bolts
    I found the same with mine, so I aligned the blade and made sure they were good and snug; recheck periodically. I guess you can use a little Lock Tight on the threads, too. I have not found any torque specs anywhere.
      Re: Trunion bolts
      If you bend the washer, it's too tight.
