Retro for Sears
  • Retro for Sears
    Ok, I've ordered the retro fence now advice on another improvement. Read in another post about the ribbed belt as a part order. Will it fit the shaft on the motor and table of a 79/80 Sears? What about the Sears BS? I must get rid of the original belts to decrease the vibration. [img]smile.gif[/img]
    Zap,
    The poly-v belt and pulleys will fit your machine with no modification, just visit www.ridgidparts.com for part numbers and prices. There are two different pulley types available, the TS2424 has machined steel pulleys while the TS2412 has die-cast aluminum pulleys with a machined belt surface. Either pulley type will work.
    As far as the band saw goes the only recommendation I can make is to use the link-belt system on the unit. We do not have a poly-v system that will fit on that saw.
    Jake
    [ 11-28-2001: Message edited by: JSchnarre ]
      Thanks again for your quick response. The parts have been ordered [img]smile.gif[/img]
