Dado blade
  • Dado blade
    What size dado can you use on the Ridgid TS3650. Is the a size restriction or is it simply the blade must be rated for the proper rpms?
    Re: Dado blade
    You can use a 6" or 8 " blade diameter. You use a smaller diameter than 10" to increase the torque value at the teeth so you can remove more material without stalling the saw
      Re: Dado blade
      Both an 8" or 6" dado sets will work on the 3650. The 6" set will put less stress on the motor and cut dados up to 1¼" deep. The 8" sets will give you the option to cut deeper dados. If at some time in the future you think that you might want to utilize a sled on your saw than the 8" set would probably be the better choice.
      ------- Henry Ford
        Re: Dado blade
        didnt consider the Sled option. I have been looking at 6's guess ill start looking at 8s now.
          Re: Dado blade
          I saw on another board that Amazon is currently running a 25% off sale on some of the Freud dado sets. The discount is given automatically at checkout but you have to make sure that you're placing the order with Amazon and not one of the other companies that offers the sets for sale. I think that would put the SD208 around $71 and the SD206 at about $64 delivered.
          ------- Henry Ford
            Re: Dado blade
            Yup. That makes the SD208 $71.23 with free shipping.Thanks!
              Re: Dado blade
              Great!
              Does anyone know if Dial–A-Width Dado works with our TS3650?
              SD608 8” or SD606 6”
                Re: Dado blade
                I have not seen one on the 3650/3660, but from what I was told by a Freud rep, the 600 series cannot be opened to full width on the Ridgid saw because the thickness of the shoulders (dial adjusters) make it too wide to install the arbor nut. It will work at the smaller widths but I do not know what the max width would be on the Ridgid arbor.
                Go
                  Re: Dado blade
                  I have a 8" Freud Super Dado and on my 3650 I can only get about 5/8" width & still use the washer & nut, If I leave the washer off I can get 23/32" which is good for 3/4" plywood. The max. cut with the Freud Super Dado is 29/32" so you woun't be able to use it's full width.
                    Re: Dado blade
                    Just a quick reminder that when you use a dado set, you do not have to use the arbor washer. The thickness of the dado blade set is enough that you only need the arbor nut to sufficiently lock down the blades.
