23 gauge pins
  • 23 gauge pins
    Here is just a little tip, I needed 1/2 inch pins and had only the 3/4 that come with the PC pin nailer. None to be found at HD, so I cut the 3/4 down to size. Use tin snips, wire cutter would not do it. Remember to cut the pointed, bottom end. Odd length pins fed through the gun without problems.
    Steve.
