3650 TS rip fence warning label
  • 3650 TS rip fence warning label
    Has anyone thought about removing the warning label on top of the rip fence . I made a duplicating T stile jig to mount with T nuts when I tighten it it makes the jig rock . it is inbetween the 2 T tracks on the top of the fence about 1/16 thick . what do yal think .
    Re: 3650 TS rip fence warning label
    Its your saw now, so you can do what you want. As long as you don't need the reminders, get rid of it (I have had mine 2 years and had to go look at the fence to see what you were talking about!! ) If you re-sell it, please make the new owner aware of the obvious if they are a novice, or include the manual which has the same warnings in it..
    Of course, if you live where there are more ambulance-chasing lawyers than woodworkers, you may want to just add additional packing tape to level it out and preserve it!!
    JMO
    Go
      Are the bolts all on the same side?
      Andy B.
        What bolts? There are no bolts holding down the warning tape on my fence?
        To the OP, just remove the tape and be done with it. The last time I looked, although it's getting harder and harder to live this way, this is still a free country.
          Yes, I have found it to be a PITA. I understand that they need to put the warning label on there, just wish it left a smooth top surface that didn't affect your jigs. I have not removed mine, but I might. I am thinking a heat gun on low will soften the adhesive up and make for an easy removal, then clean an residue off and you are good to go.
            How about buy or borrow some mailing labels from the office or office supply store and put them on your fence to "level" the surface. You know, labels the whole length and width should stop your jig from rocking. Ugly, but effective, maybe?
              Ha! Warning label? What warning label? I didn't know there was one. What do it say?
              I was going to build a jig to allow me to cut thin slices close to the blade, but abandoned the idea when I felt that lump on top. Now I know why the fence has a lump.
              Incidentally, Long Hair on this Forum shared a better way to do the job anyway. Works like a charm! Thanks to you Amigo.
              Blind Bill
