BS1400 Riser Blocks Are HERE!!!!!
  • BS1400 Riser Blocks Are HERE!!!!!
    It is currently 6:58 pm central standard time. I just got off the phone with Ridgid parts. I was advised that the fences and the riser block kits arrived today and will begin going out this week. Thought some folks might like to know. [img]smile.gif[/img] BS1400 Riser Blocks Are HERE!!!!!
    I came...<br /><br />I saw...<br /><br />I changed the plans.
    Thank you for the update!! Hope the riser block kit is on the way. Appreciate you posting this for all of us.
      I was just told I'd have it buy the 26th. Cool
        WOOHOOO!!!
        I'm excited for everyone who has one on backorder. Hope they come soon.
        Jake
          To use the riser block, do I need a longer blade? If so what size should I look for?
            Talk to folks at Suffolk, and they'll set you up with custom blades to accomodate the riser blocks.
            Good luck,
            Jack
              If you have the standard 93-1/2 blade, adding the riser block will require a 105" blade. Also a standard size.
