Router Table for 2412 TS
  • Router Table for 2412 TS
    Hi, I am not sure if this question has been asked before but I cannot find any info on it...
    I would like to replace the right side extension table of the saw with a router table that could be used with the existing rip fence. Does anyone know if there is an aftermarket table available or where I might find a plan specific to the Rigid TS?
    I think that using the table saw base would be much more steady than any other type of router table....and save some space in the shop.
    Thank you,
    Joe Regan
    The only router table available to replace an extension that I know of off the top of my head is a unit made by Craftsman. Rockler also makes a router table mounted to a table saw but it more of a table that is just bolted to the saw rather than a replacement of an extension.
    Hope this helps!
      Hi Jake, thank you for the reply. I found the router extension table that you mentioned in the Sears Tool Catalog. The item no is 25351...price $99.99.
      I will check it out.
      Joe Regan
        Joe: If you have not yet found the router table your loking for you make want to check out they make a table that will fit the Ridgid TS2424, In fact in the picture of the table they have it mounted to the TS2424. It run about 350.00. If I remember the tabke is cast iron. I've looked at the table the Sears sell's it nice but I thing I would like to have a table without the groves. I hope thia is some help.
        Dan<br /> <a href=\"\" target=\"_blank\"></a>
          Daniel, I figure you're referring to the ProTop Extension (RT250) from Bench Dog, right? It is a laminated MDF table, not cast iron.
          The only solid cast iron router table manufacturer I'm familiar with is NuCraft. Here is a company (that I know NOTHING about, they just showed up in a search) that sells NuCraft:
