TS3650 angle indicator
  • TS3650 angle indicator
    I set the blade to 45 degrees, confirm with a square, then set the indicator arm. But when I return it to 0 degrees, the blade is correct according to the square, but the indicator arm is about an 1/8" away from the 0 mark.
    Re: TS3650 angle indicator
    Go get yourself one of these and don't worry about anything else. This is all I use anymore and I never have to guess or worry that I'm slightly off.... Click the link, this is well worth the extra dollars.....
    http://www.woodcraft.com/family.aspx?FamilyId=5894
      garager has the right idea. The Wixey and also the Beall angle guages take all the guess work out of setting the angle of the blade. They also are great for squaring up the jointer fence to the jointer table, aligning the DP table to the drill chuck and tons of other uses.
        I've never relied on any tool's built-in angle measurement. They never seem to be accurate. Like Garager, I have the Wixey digital angle finder. GREAT tool! I can't say enough good things for it.
          I too have the Wixey digital gage and love it. it is so much better than trying to see the light between a blade and a square. as the others have said buy it, you wont be disappointed
            Thanks all for the advice. I will purchase a Wixey Digital Angle Gauge. It is exactly what I need.
              craiga, do some shopping around for that Wixey. They usually sell for around $39 but someone usually has them on sale for around $30 or so.
                I have no affiliation with the company, just did a search like BD mentioned and this is the cheapest I've found so far. Now to figure out how to buy it without my wife noticing the money missing from the account.
                http://www.craftsmanstudio.com/html_p/C019003.htm
                  Check for buckling in your case. This is throwing off my angles most significantly at 45 degrees.
                    I have a question on the wixey digital guage. Will that work if the saw is not on a level surface? I would think it would need some sort of reference and if the saw sits on a floor thats not level how does the guage work?
                      Good question. There's a button to zero out the reading to whatever reference angle you want. In this case one would zero it out to the table of the saw in order to set the reference plane and then measure the angle of the blade in reference to the table.
                        Interesting. I was thinking something to the effect you need to start with the blade at a perfect 90 degree angle before the wixey could be used. But using the table surface is much easier and removes some user error if the blade wasnt perfectly set at 90 degrees first. I think I am going to get one - my bday is coming up, good excuse to buy myself a new tool.
                          The Wixey does not require the TS to be level, though for the operator it is usually nice if it is.
                          The Wixey measures the angle relative to where you zero it, so if you place the gauge on the TS top and zero it out then wehn you stick it to the blade using the magnets and tilt the blade it will measure the angle in relation to the table top.
                            you place it on the table and press the Zero button. then put it on you're blade and it will show the difference in angle.
                            the gauge doesn't care if the table is level or tilted 20 degrees, it will show the angle between the two planes.
                              You can zero it out to the table top and thus ensure your 45 degree (or whatever) is accurate in relation to the table top.
