Jake, TP1300 Set Up Instructions
  • Jake, TP1300 Set Up Instructions
    Hi,
    When I set up my TP1300 and adjusted the in and out feed tables according to directions, the machine produced 3 inches of snipe. The board was smooth but I did not like the idea of wasting 6 inches of wood on each board planed.
    With the tables raised - maybe a quarter turn at most - snipe literally disappeared. I have only planed a few boards but the results are very good.
    Jake, I think the set up instructions should be changed. I doubt I would have gotten such good results without having read this set up suggestion on these message boards. My 2 cents.
    Best regards,
    Henry
    Henry,
    Thanks for the suggestion. In most units, the instructions as written seem to work fine, but every so often, it takes a bit of tweaking from there.
    Jake
      Jake, as I get further into woodworking I am finding that *tweaking* and learning how to control and combine the tweaks is what determines your skill level. Thanks for responding.
      Best regards,
      Henry
