Adjusting the squareness of the blade (TS2424)
  • Adjusting the squareness of the blade (TS2424)
    Well,
    I bought my TS2424 a whiel ago and promptly assembled it. THen of course my wife and I bought a house which meant the beast had to be moved.
    Well, for whatever reason, now that it's assembled again in my new house, the blade isn't quite straight.
    I'm just wondering if there's an easy way to adjust that without having to take the motor off and such to get in there. I don't see a way from looking at the manual, but thought maybe someone here had to do that and would know.
    Thanks,
    --Mike
    Mike, which "square" are you referring to? There is square to the table, and parallel to the miter slot. Neither adjustment should be made with the motor off, as the weight of the motor affects the adjustments.
    Dave
      <BLOCKQUOTE>quote:</font><HR>Originally posted by Dave Arbuckle:
      Dave
      <HR></BLOCKQUOTE>
      Dave,
      After re-reading your post, it becomes obvious, but for those who only read this once, DO NOT TURN ON THE MOTOR to make this adjustment!!
      Dave's saying to make sure the motor is attached.
      Bubba.
        Oh, cripes!!! Thanks, Bubba. Please revoke the word "off", and replace it with the word "removed", then it reads correctly.
        Motor installed and unplugged, there's the way.
        Dave
        Where's my coffee?
          I'm referring to Square to the miter gauge. When I push soemthing through, ti basicalyl cute with the front of the blade and then cuts a bit more at the back. WHen I looke din the manual, it looked like you are supposed to adjust that part before you attach the motor since when the motor is attached, it's hard to get up under there to adjust anything. Unless I just read it wrong.
          But anyway, standing in front of the saw, the blade is angled slightly from left to right from front to back.
          --Mike
            Parallel to the miter slot, then. I avoid saying "square to the miter gauge" because setting the miter gauge square is a separate, later, setting.
            It is a little difficult to get under there, but the only way to get excellent results is to make the adjustment with the motor installed. The motor is so heavy that removing it allows the cradle assembly to shift slightly.
            If your TS2424 is a "-0" model, like mine, I recommend investing in a little dingus called P.A.L.S. This is a pair of brackets and bolt replacement studs that fit onto the rear trunnion, and allow you to adjust the parallelism with an allen wrench. Makes it very easy to get a great setting. Hardest part of a P.A.L.S. installation is figuring out the instructions, they are a bit cryptic. http://shop.woodcraft.com/woodcraft/...=false&Giftid= , the TS2424-0 uses the one marked for Sears Craftsman.
            If you have a "-1" model, your rear trunnion has this adjustment built-in, and should be pretty easy to set.
            Dave
              Dave...I have a T2412 that I got about 2 years ago, are the P.A.L.S. adaptors available for this saw? I have notices that when I cut the lumber is often away from the rip fence at the rear position when is gets past the blade whil still being in contact in the front.
                I think the rear trunnion is the same, that's what would matter. Since Jake is away on his much-deserved Holiday, maybe give the support line a jingle, they should be able to answer this easily. It's 800-4RIDGID, as I recall.
                Your issue can be caused either by the trunnions being out of line, or the fence being misadjusted. Be sure you aren't curing the wrong problem.
                Dave
                  Re: Adjusting the squareness of the blade (TS2424)
                  I have a ts2424-0, and my problem is getting the 1/8 clearance. the front trunnion will not shift far enough to the right (front view). Get about 1/16 inch only. Messing with the tilt mechanism is not the answer because at 90 degrees I'm right back where I started.
                    You have to excuse me for being dense. I always use stabilizers on my blades, but removed them when I did the tune up. Adjusting the front trunnion I could only get 3/32 clearance. When I put the stabilizers back on the clearance was perfect. In a pure sense, the problem with the 2424 clearance is not resolved,but the stabilzers are the perfect correction.
