Box Joint Problems
  • Box Joint Problems
    I made a 3/8" box joint jig and have it mounted on an Incra miter guage. I am using a Freud dado blade on a 3650 TS. This is my first attempt at making drawers. I have been working with scrap 3/8" scrap stock for practice. As I go across the 3 5/8" width, I find the slots are getting tighter across the stock. The pins all measure 3/8", I have moved the key closer to the blade to increase the slot width. The distance between the pin and blade is approximately 19/32". What am I doing wrong?
    Thanks Phil
    Re: Box Joint Problems
    You can't "adjust" the slot width with the jig, only the pin width. The slot width is determined by the dado blade. It sounds like your blade needs a shim. That would mean that the alignment pin is too small also. They must be exactly the same size.
      Thank you for your help.
      Phil
