Need Help
  • Need Help
    I am building a desk that the top is designed like a shadow box. I am placing 1/4" cork sheet to bottom.
    Can i use a spray adhesive? Is that the best way?
    That could get very messy...
    If you wanted to use it, I'd lay the cork sheet in place, lift a corner, spray a dab, drop it, & do the same in all corners.
    Double sided tape, installed the same way, might make it easier to replace, if you ever wanted to.
    And you could use a small vacuum to lift the corners, if they are hard to get up!
    IMHO...
    Have FUN! Joe ... www.woodworkstuff.net ..... My Small Gallery: http://www.ncwoodworker.net/pp/showg...0&ppuser=1389/
      I've seen and used cork sheet that is adhesive backed. Easy to use. Otherwise I would just use white glue.
      www.TheWoodCellar.com
