Sharpening Forstner Bits
  • Sharpening Forstner Bits
    If you can you want to run this video in high quality. Look for the blue letters to link you there. Remember these guys have been doing this work for a long time. They are skilled and make it look easy. This is a job for experts and isn't a DIY project. We can't afford the diamond grinding wheels and special grinding machinery.
    YouTube is having technical issues again. This may or may not work. If it fails, try going to their main site and in the search box type in sharpening forstner bits
    http://www.youtube.com/watch?v=bt4weRZs0HM
    Re: Sharpening Forstner Bits
    I always just used a good ol file. I only went through one bit insulating my entire house.
      I used files, but now use wet/dry paper wrapped on a flat stick for the straight cutters and around a dowel for the inside of the edge cutters. I use the same on spade bits that have the spurs on the outside edge and for brace bits and augers.
      This guy must have fingers of steel to take the heat.!!
      Go
        Go
        Steel hands and stupidly brave too. I've seen his other videos and it would seem he loves his eyes but hates his fingers. In one video that I should post in the Safety section of this forum, I really thought he was going to seriously skin himself.
          unfortunately the video link reports as no longer available.
          Went to YouTube and was able to watch it.
            For sharpening my self feed bits I use the $10.00 pneumatic angle grinder with the small sanding discs that are swapped out on the 2" hard rubber base.I use an extremely light touch to keep the angle and tooth length on the cutters uniform.It is very important to maintain the .030 or more required on the shaver bit.If the shaver is too high the bit will just hop,too low and it won't be able to shave out the excessive wood.
              drtyhands: Thank you for reminding me!! I have a pneumatic die grinder and it has set in the cabinet for a few years, mainly because I forgot i had it!!.
              Go
                Originally posted by Bob D. View Post
                Unfortunately the video link reports as no longer available.
                I'm having the same issue. If you go to the YouTube main site in the search box try typing in something like Sharpening Forstner Bit that should help. YouTube has been having technical problems and is trying to fix them. I hope it time they catch up but they have their hands very full of work.
                  Freehand sharpening is fine if you're using your bits for making rough holes, but for fine woodworking you want your tools sharpened by a professional shop on proper equipment. Frankly that shop in the video looks like a circus.
                    I would hate to send my bits out for sharpening and find out it was this guy free handing them!
                      All of you need to see the total Jack@$$ with ExpertVillage on how to hand sharpen a chainsaw chain using only a round file? He is filing the teeth in reverse.
                      Someone that does know how can touch up teeth with a round hand file and it works fine but you do need to have a good sharpening service with proper equipment sharpen chainsaw chains. There's far more to it than meets the eye.
                      I agree with PapaDan and Newman. NO way would I want to freehand grind a good Forstner bit.
                        so how are do you travel to a true sharping shop, it would be three hours for me to even go to find one, so I find free hand fairly good alternative,
                        and if you learn how to sharpen things one can do a very good job, the trick is in the know how. IMO
                        yes a good machine will out do freehand if it is a good machine, I have a good machine for sharpening chain saws, it cost me as much as the one saw did, and more than other saw, but worth it. for speed and accuracy of sharpening but you can really mess things up fast too, if it got set wrong or knocked out of whack,
                          I take my saw blades and carbide bits to a local saw shop and they have a ton of modern equipment, and do a nice job.
                          I did sharpen my chainsaw by hand a few times and it worked well, but it's far too time consuming to do it right.
