Forstner bit in plunge router?
  • Forstner bit in plunge router?
    Is it safe to put a Forstner drill bit in a router?
    In order to drill a collection of 3/4" bench dog holes I figured it'd be easiest and most accurate to put the bit in a plunge router, but I'm not sure if this sort of thing is typically done, and whether it'd be safe.
    Thanks,
    --Jeff
    Re: Forstner bit in plunge router?
    I'd be willing to be the router would spin to quickly and damage something or even hurt you. I would definitely not reccommend. it.
    Ryan
      The maximum speed for a 3/4" forestner bit is 1200 rpm for hardwood, the minimum speed I have seen on a VS router is 8000 RPM. The collet size will also be incorrect to hold the bit.
      BAD IDEA
      Use a drill press or a drill guide
        NO!NO!NO!
        NOT SAFE
        enough said
        Cactus Man
          Believe it or not, my first response to reading this was to check the post date to make sure it wasn't April 1st
          Definitely a VERY bad idea! I'm am glad you asked first though... saves some rather expensive hospital or even funeral bills.
          As previously offered, get yourself a drill-guide, they're available from many different sources including Sears, Rockler and (I believe) Home Depot. Cost... about $30 - $40.
            What everybody else said. With that said, here's another caveat -- Make sure you check the recommended speed on any type of a bit, saw blade, cut-off blade, drill bit, hole saw, etc. before you put it into something with an electric motor and spin it up to speed. There are definitely things that will fit on a 4.5 inch angle grinder that will self-destruct if you ramp them up to 11,000 rpms. There are abrasive cut-off discs for a circ saw that will fit a 9-inch angle grinder that will also explode. And believe it or not folks, but most of you are probably spinning your hole saws WAY too fast, so check on the recommended max rpms before you chuck those in a drill and spin them up to 1,200 rpms and burn them out.
            Cheers,
            Jim Don
              You might try using a 3/4 dia router bit to plunge down as far as you could, then, using that hole as a guide, use whatever you want to drill through. The router may want to wander a bit when starting though.
                go for it. get video. post it up while you are healing.
                  Thanks,
                  --Jeff
                  As others have said, do no put that forstner bit in a router....
                  Since I'm in the planning and prepping stages of a workbench, I thought this was slick as snot and it really stuck in my mind:
                  I just happened to see a show the other day on DIY that dealt with workbenches, and they had a slick jig for drilling the dog holes. It was a portable drill guide, fixed to a board, with an attached cleat to provide a fixed distance from the bench edge. Additionally, they had a 3/4" hole in the jig which you could use to reference the previously drilled hole, so they are a consistent distance apart.
                  Drill guide:
                  http://www.acehardware.com/product/i...ductId=1297823
                  and these, or a 3/4" hardwood dowel (to serve as the reference):
                  http://www.leevalley.com/wood/page.a...77&cat=1,45866
                  http://www.leevalley.com/wood/page.a...=1,41637,41645
                  If you just want to freehand it for minimal cost, try this:
                  http://www.rockler.com/product.cfm?p...forstner%20jig
                  (the Jig-It drill guide).
                  Good luck and be safe!
                    As has been well noted, using your router is a bad idea.
                    As an alternative, how about an old fashion brace and bit. It's easy to make a flat-bottomed hole if you don't want to go entirely through the top and it's also easy to make a slightly slanted hole so the bench dog can "pinch" the work piece in place which is sometimes desirable?
                    Hope this helps.
                    Bill
                      Sorry for raising up this old thread, but it does come up first in Google if you're searching on "Forstner Router Bit", so I thought I'd mention something...
                      There ARE router bits that serve (basically) the function as forstner bits, and, since they're made for routers, they're perfectly safe to use there. The problem is that they are not called "forstner bits", and so when you search for "forstner router bit" on online you only find this thread
                      If, however, you search on "hinge boring router bit", you'll find pages of kind of bit you might be looking for, like this:
                      http://www.amazon.com/s/ref=nb_sb_no...er+bit&x=0&y=0
                      ...you'll notice that the router versions do not have the side-walls that the forstners do - because they don't need them for alignment and because they spin so fast that you don't want them.
                      Anyway, if you prefer a router + jig for your shelf-pin holes, then you probably also prefer using one for your hinge cup holes, and maybe you're looking for these bits...
                      Cheers,
                      CList
                        Thanks for the info and welcome to the forum
                          I found this question /thread by searching for the topic in Google. I am looking for a way to drill lots of 3/4 inch bench dog holes in a 2 1/4 inch hardwood bench and found the following link that gives a video demo of how to do it with a plunging router, a simple jig to keep the router fixed and a special bit (actually, a 3/4 inch "spiral upcut bit").
                          http://www.popularwoodworking.com/ar...nch_Dog_Holes/
                          This seems to have been written/videoed about the same time this thread was active. Hope you all find this scheme as easy and safe as it appears.
                          ghopper.
                            Great find. I am sure that little jig can save alot of frustration on getting the holes to all be in line.
                            And Welcome to the Forum.
                              People call me the mad carpenter because quite frankly if it isn't safe i'm the man that will do it. how ever if it is stupid i leave that to my brother, so to answer your question i made my brother try it out. Needless to say he took a trip to the hospital. with lacerations and a broken wrist. My suggestion Use the drill press. if you don't have one buy one
