Saw Dust Collection for New TS3660
  • Saw Dust Collection for New TS3660
    I recently purchased a new ridgid TS 3660. I"m pleased so far. I purchased a dust collection bag that fits under a normal table saw. The Ridgid however has a front and back support the sits lower then the two side supports so it will not fit. The Ridgid web has little in the way of accessories.
    Where do I get dust collect for my new saw?
    Thanks.
    Joe T.
    Re: Saw Dust Collection for New TS3660
    Joe if you search the forum a little you will find several threads that have home made enclosures. I made mine from mdf. 3/4" in the bottom with a plastic dust flange siliconed in to attach a 4" hose to it and 3/8" with cut outs for motor mount and belt in the rear. good luck Pat
    this thread has a pic of one way, I know I've seen several others. Let me know if you need pics of mine
    http://www.ridgidforum.com/forum/sho...ust+collection
      Thanks PMR413. Very helpful. I'm new to this board but I think I'm gonna love it!
        The simplest method is to just connect a shop vac to the port on the blade shroud. I'm pretty sure Ridgid designed it to operate this way.
        This is the upside down view...
          Your welcome and welcome aboard. If you need I can post some pics of what I did just let me know...
            you might use this in place of the dust collector bag you mentioned:
            http://www.pennstateind.com/store/R-TDHOOD.html
              Joe I also remember reading a thread where someone said they enclosed their 3650 and tested with the factory dust port removed. With the port on the dust collection was better, so if you go with a dust flange like I did mount it towards the rear this way when you swing the blade to 45 degrees there is clearance for the factory port to swing across.
                Pat,
                I would greatly appreciate your dust collection pics and thanks again for your help.
                Joe T.
                  Thanks FINER9998. Have you tried this attachment?
                    Thanks JBATEMAN. Have you used this dust port? Looks like it would not capture all the dust.
                      I'll try to give a short description of each picture, I did a cardboard mockup of each board. I put magnetic tape onto the rear main board to help seal the rear also used 2 bolts and fender washers on it to make sure it doesn't vibrate loose, and used large fridge magnets to close up the front holes. I don't cut bevels very offen but when I do it takes about 3 minutes to remove the rear so I can tilt the blade. Pat
                        Only 5 pics per post... and yes I have my lift on backwards, I push the front of the saw against the wall (then drop it down) and let the motor stick out. hope this helps you.
                          Pat,
                          OUTSTANDING!! Thanks that is a great help.
                          Joe T.
                            joe t...i was able to purchase a discontinued ridgid product, in plastic, for $7.00 some time ago which looked a lot like the product i linked in the post but came with a 2.5" dust collection port. i modified it to accept both the standard 2.5" shop vac dust collection hose and a 4" fitting for a Delta dust collector. i am capturing far more dust now than ever but, as my product is no longer available, i would definitely try the product i linked you to. they look almost identical and the linked roduct is make of metal. btw, this si the ridgid product i mentioned
                            http://www.ridgidparts.com/pdf/AC1098.pdf
                            and this is the kit i used to modify the ridgid 1098 so it accepted a 4" hose from a dust collector
                            http://www.westerntool.com/product.htm?pid=437005
                            hope this helps. btw, great job closing up the back of the saw.
                              pmr...can u provide more info re materials and techniques to attach the materials to the back of the saw to close it up?
