Ridgid Router
  • Ridgid Router
    I recently purchased a Ridgid Router Combo. I am trying to find a router lift to fit this setup. Can you help me locate a lift, or point me in the right direction? Thanks
    Re: Ridgid Router
    I'd suggest checking out www.rockler.com to see if one of their lift kits will work. There appears to be some compatibility between the Ridgid 2930 and the Porter-Cable 690, but I'm not sure if the motor asm diameter is the same. If so, probably any motor lift would fit.
    I hope this helps,
