ridgid r 2720 belt sander-breaking belts
  • ridgid r 2720 belt sander-breaking belts
    I looked in the manual and can't find anything in regards to belt adjustment (tension)so I assume the belts are put on and the unit self adjust the belts. Went through several belts recently and little pressure was applied while working on the stock. My question is, could the sander be causing this or a bad batch of belts? My sander is a month away from the 3 yr. warranty. Wanted to correct the problem before Jan. 1, 09. thanks, kenny
