Problem setting up ridgid 12" compound miter saw
  • Problem setting up ridgid 12" compound miter saw
    I was setting up my new miter saw per the instructions and after completing the second bevel cut through the zero clearance plate, it locked in a 45 degree bevel and I can't get it to move an inch. The bevel stop knob won't budge. Any thoughts on what I can do?
    Re: Problem setting up ridgid 12" compound miter saw
    Make sure the bevel lock lever is disengaged, the bevel stop pin is disengaged and that the saw body isn't hitting the fence. I had to remove the fences for the 45 degree cuts.
    This is for an R4121.
    Good luck
    ken
    Poplar Branch Wood Crafts
