Laser problem on new R4121
  • Laser problem on new R4121
    Just purchased, unpacked, and used my new R4121 miter saw. The laser does not illuminate the work surface. The laser is working when you push the button. I can also see the laser when the saw is running in the full upright position, just is not illuminating the surface to be cut. What is wrong and how can it be adjusted/fixed?
    Re: Laser problem on new R4121
    The laser should be adjustable to point down to the work piece. The manual should walk you through the procedure.
