Auxillary Fence
  • Auxillary Fence
    What purpose does an Auxillarly fence serve? I've seen examples in books and the such-like, but the bottom-line is that one way or another the workpiece is still touching the auxillary fence...much like it would touch the fence itself.
    So wherein lay the difference?
    I normally use an aux. fence when cutting rabbets with a dado blade. It's higher than the Bies and has a T-slot that allows me to attach a finger board for a hold down.
    I also use it when cutting zero clearance inserts.
    I guess I use it anytime the Bies would be too close to the blade.
    Bob R
      I made an aux fence for my 3612. I put a t-slot channel in it and use it when I need to bury part of a molding cutter or dado blade and when I use featherboards although they will also hook to the regular fence.
      I don't leave it on there all the time because you can't really use the fence measurments.
        Not only is an Auxillarly fence useful for the previously mentioned uses, but I keep an Auxillarly fence on all the time as a european style fence. The end of the blade stops just before the arbor. Really eliminates the possibility of kickbacks. I have a second Auxillarly fence for the purposes mentioned above.
        I came...<br /><br />I saw...<br /><br />I changed the plans.
          I see, makes sense. Thanks!
            Sorry, cant read what I type. My last post should have said the end of the fence ends a little before the blade arbor. I think most european fences end right at the arbor, but I have found that a little before, approximately 1 or 2 inches is a little safer and actually very easy to get used to. A splitter is still required of course.
              Thank you, GW!
