Joint'R Clamp?
  • Joint'R Clamp?
    Since I don't own a jointer, I have to be inventive about getting a nice edge on my boards. Up to now, I've developed a way to joint on the router table, which works great.
    But then I found out about the "Joint'R Clamp" device, which is a device that does jointing on the table saw.
    Seems like it would work for 1x, perhaps plywood. But I would be hesitant to use it on rough lumber.
    Opinions?
    Here's a link to the device:
    http://www.woodcraft.com/family.aspx...&FamilyID=3203
    I have one and have used it on rough lumber. It works well with a good rip blade. I wouldn't use it on anything more than 4feet long, doesn't do such a good job then. On plywood it depends on the quality of the plywood on how good a job it does.
    I have a jointer now and have no need for it. If you want it you can have it for $8 including shipping.
    www.TheWoodCellar.com
      I will take it. That is definitely a bargain.
