13" planer won't lock in place
  • 13" planer won't lock in place
    My new TP1300 planer (orange and grey model) won't lock in place and it takes about four passes to get a board to consistent thickness. The sure-cut lever lock...yes, I am using it correctly...does not hold the carriage (cutter) head in place. I have done the fix suggested in the manual several times but that has not fixed the problem. Ridgid customer service only suggests the manual's fix. Anyone got a solution to this problem?
    Try this thread.
    http://www.ridgidforum.com/cgi-bin/u...;f=15;t=000355
    Lorax
