Router Table on my 3650
  • Router Table on my 3650
    Does anyone have a good plan for putting a dedicated router table on the right side of the 3650? I have seen a few pics here of this arrangement and it really works well, but I do not have a good idea/plan for one. Could a few of you share your ideas and techniques with me? Thanks!!
    Re: Router Table on my 3650
    Hi L. Scott,
    I added the MCLS router table that fits nicely between the rails on the right side without removing the wing. Here is a link to their table
    http://www.mlcswoodworking.com/shops.../tabletop.html
    It comes with a wood reinforcing frame screwed to the bottom. I removed it and proceeded to drill 4 sq. pockets equally spaced from the bottom with a forstner bit. I then drilled clearance holes from the sides into the pockets, and installed 1/4" bolts, washers and nuts. I slid the unit in and it works perfectly.
    Measure twice and drill once so the table lines up flat with the wing and you have a little wiggle room for final adjustments. The beauty is using the Ridgid fence with this table. I am going to make a connection to the TS fence and the supplied router fence.
    Wish I could send you better info, but I'm hiding from the Chicago weather here in Florida so I can't physically take pocket depth measurments etc.
    Hope this helps.
    P.S. I mounted a Freud plunge router that comes with a crank. It works real well
      I also added the MLCS router table to my 3660. My mounting method, I think, is almost identical to tierraverde's. I left the right extension wing in place and drilled three holes through the end so I could run 1/4" lag bolts into the router table frame. The sides are supported by four bolts riding in the rip fence rails.
      I have some pics in my album: http://www.ridgidforum.com/forum/album.php?albumid=68
        Here is a good thread that I am currently using to mount a router extension using angle iron.
        http://www.ridgidforum.com/forum/showthread.php?t=11380
          tierraverde,
          I don't really understand your directions as to how you installed your MLCS table. I am really considering buying that same router table. Can you post some pics or explain how you did it so an idiot like me can understand!
            I can't supply pictures as my TS is in Illinois and I'm hiding from the weather down in St. Pete FL.
            Maybe I can help if you email me with your phone #. I'll call you and we can go over it.
            (tierraverde@comcast.net)
            I think you'll like the method once you understand it.
            Jim Ceriale
              I'll attach a picture (.jpg from Sketchup) of one I made from 3/4" melamine-coated fiberboard and scraps. Opening is for a Rousseau lift (9x12). I also added some 1x3 bracing between the bottom of the table and the 3660 legs to take the stress off the fence rails. It won't last forever, but then maybe I can start saving up for a nice steel extension from Quality Grinding... heh heh.
              If you have Sketchup and want a copy of the project, PM me and I'll email it... the forum doesn't allow .skp files as attachments, so may need to get your personal email.
                I have one of the aluminum Craftsman Professional router tables. It fits perfecly between the rails and i can leave the wing installed.
                  If you look at my post http://www.ridgidforum.com/forum/showthread.php?t=23571
                  and like this approach I could give you more details.
                    Re: Water pipes
                    Originally posted by jkjllkj
                    Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
                    of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
                    used some of the parts to make my babington wvo burner.
                    Ummmmm....I think you posted this on the wrong thread
                      Re: Water pipes
                      This air fittings guy seems to be about the most persistent spammer there is. I report this guy at least 2x a day.
                        Was just wondering how much work will be involved in just filling the gap at the end of the TS. Don't need it for a router table
                        Deep Thoughts: If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason.
                          Very little effort is needed. I just used some angle iron (cut down to two ~20" pieces, if memory serves), a few nuts/bolts, a 1" thick piece of melamine coated fiberboard, and some screws. It took me < than an hour to have it all mounted to the saw. I can take some pics of my simple set up later today... There's the option of buying another cast iron wing too.
                            Thanks, I just noticed the slots on my rail, duh
                              So, do you need pics? Obviously I didn't do that the other day...
