What Happened To My Table Saw Sled?
  • What Happened To My Table Saw Sled?
    Awhile back I made a very basic table saw crosscut sled out of ¾" ply and I used oak for the runner. It worked just as it was supposed to for months without any issues. Today, I went to use it and it no longer sits flat on my saws top. The wobble is very noticeable and I feel uncomfortable using it.
    I'm looking for some ideas on what not to do when I make another. Should I have used a different material instead of ply? I can't remember for sure but I think I made this based on a design from WOOD Magazine or Shop Notes and it called for using ply.
    I'm also wondering if possibly I didn't store it correctly when it wasn't being used. For those of you who use a sled, how do you store yours during downtime?
    Re: What Happened To My Table Saw Sled?
    I made one after first reading about them and after a while, I decided it worked best in my wood burning stove.
      Is the wobble in the ply, or is it somehow in the runner?
        If you lay the sled on the saw with the blade all the way down and the runners up does it still wobble? This will tell you if it's a problem with the runners alone. The oak may have swollen/shrank unevenly. This could cause the ply to warp. Try taking the runners off and see if the ply is warped.
        To alleviate the problem in the future, you can purchase aluminum rails from Woodcraft or Rockler. Using those runners, you shouldn't have any more warp problems. Remember to store the crosscut sled flat.
          As Sandy suggested, I removed the runner and it appears the ply is where the issue is. I'm also leaning towards the way I stored the sled as the cause. As is the case with many of us, I just don't have a lot of storage area so I was storing it standing up on end and not laying flat. Being fairly small I really didn't think storage would be an issue but live and learn I guess. If I make another one I'll have to figure out a way I can store where it would be laying flat.
          Maybe PK can use the warped one for making a little heat.
            I've got the same shop-space situation as Badger Dave, and am planning on making a sled out of ply over the weekend (just cut the runner last night out of maple).
            So, what about hanging the sled from one end of the ply, do you think this would cause it to warp also?
            Thanks!
              what about making the sled base out of MDF? flat, stable, reliable. use hardwood for runner and rear/front fence.
                That's what i did and it has stayed perfectly flat........1/2 inch MDF for the sled and oak slats for the runners
                  I also used 1/2 inch MDF and I store it leaning against a wall. Still flat. I used a strip of 3/4" ply for the runner.
                  I think that 1/2" is better than 3/4" just because it doesn't raise the table height so much.
                    "Maybe PK can use the warped one for making a little heat. "
                    BD, I could use it for smoking Walleye if it is clean wood.
                      Try MDF and put a hang hole in it . Gravity will keep it flat then
                      instead of warping it as it did when leaning up against something.
                      cpw wrote: "I think that 1/2" is better than 3/4" just because it doesn't raise the table height so much."
                      I agree with the 1/2". It's also not much trouble to make the opposite half to compliment your sled.
                      I made my sled for use on the right side of the blade. And I made a piece that has a runner on it to
                      keep it positioned to the left side, and a piece 24"w x 48"d(front to back) that slides up along the
                      edge of the left wing. There I use a c-clamp to secure it from moving. The sled (36"w x 24"d) then
                      travels on the right side of the blade. Any offcuts do not fall as they are supported by the other half
                      on the left.
                      Next time I use it I will try to remember to take a photo.
                        Now that's hitting below the belt.
                          If you built it from ply bought at HD that is your problem. That Ply comes from China and is about as stable as jello. It warps, shrinks, delams, cracks, and has been found to have metal imbedded in it on occasion.
                          I wouldn't burn it because none of us know the glue formula remember these are the people that cut their baby formula with wacked chemicals to get more profit.
                          Rev Ed
                            ...I wouldn't burn it... [plywood]
                            I never burn plywood no matter what the source. Too much glue.
                              So would there be general agreement that MDF would be a better choice for a crosscut sled?
                              In order to understand recursion, one must first understand recursion.
