Broken Rip Fence Handle TS2424
  • Broken Rip Fence Handle TS2424
    Well as clumsy goes, the rip fence fell and landed on the plastic handle...and yes it broke. I have ordered one and it's on it's way, but am perplexed as to how to replace it...anyone ever done anything like that before.....
    Any help is appreciated !!
    Tony,
    Actually it's pretty easy. Loosen and remove the 1/2" nut on the back end of the fence. Once you have removed the nut, the handle should pull out from the front of the fence, along with a long rod. Set the two bearings to the side and pivot the handle so the rod can be side out from the front of the handle. Slide the rod completely out and push the round insert out of the handle. Put the insert into the new handle and reassemble.
    Jake
