Differences
  • Differences
    Would some one be able to tell me what the difference is between BS1400 and BS14001.
    TP13000, TP13001 and TP13002. Also how do you tell the differnce between the 2 or 3. HD did not know.
    THis is a "Jake Special" as he will be able to tell you , If no answer on the web call him, I found him to be very pleasent on the phone and HE IS VERY KNOWLEDGABLE about many topics.. dd
      The difference between the BS1400 0 and the BS1400 1 is a TEFC motor on the -1 model
      The differences between the versions of the thickness planer are minimal. The -2 version includes a legset in the box.
      We use the last number of the model number to track minor changes to the units. Usually its a parts changes and completely transparent to the end user. If inventory is correctly controlled the only unit available should be the latest dash number.
      Jake
        Thank you Doc and Jake,
        Both tools are working out great I just wanted to make sure that I got the most bang for my buck.
