Need some advice on how to avoid scorch marks
  • Need some advice on how to avoid scorch marks
    I recently purchased a Ridgid TS3660 and it has performed marvelously thus far. Today while ripping some 5 foot long 3/4" thick oak boards I find that I'm getting some pretty serious scorch marks along the one face of the boards, actually smoking as I push them through. Since my plan is to edge glue a number of these oak boards together, I've been advised that these boards do not hold glue well. I've purchased a brand new RIDGID R1060, 60 tooth Titanium coated FINITION blade for the job. Does anyone have a solution as to what my problem might be?? Is it the blade?? I've been told that to edge glue boards that I need a smooth cut and a combination blade works best, what I thought I had put on. Any advice as to how to correct this problem would be greatly appreciated before I cut any more boards.
    New guy from northern Canada,RSJ
    Re: Need some advice on how to avoid scorch marks
    If you're getting scorching it could be a bunch of things. One is if your feed rate is too slow, another is if your fence/blade are not quite parallel or the wood itself is closing in on the blade. Do you have the splitter on?
    If you have an appropriate hand plane and patience you can clean up the edges, better for gluing than a saw.
      How much wood have you run through that blade? Recently doesn't tell us enough about the volume of wood cut or type. Process of elimination,can you afford another blade? Getting much kickback? Did problem start prior to new blade install? Did you check new blade ?
        As far as I can tell everything is parallel, runs plywood through without much problem and the splitter is on and I can't seem to push the wood through much faster then what I'm currently doing. The blade is pretty well new, hardly any material run through it, some 1/2" to 3/4" plywood and not much of that. I've had a Freud blade on my Craftman before purchasing this RIDGID and I had that blade on for at least 10 years with no sharpening and it still cuts better then this one. Been doing some more reading in this forum and thought that perhaps I need more of a ripping blade for this task. Not getting any kickback but you can feel the force pushing back though.
          If you are getting force back at you, it could be the wood is trying to close up. Are the pieces you get out straight?
            Yep, they were coming out straight, splitter was working fine. I haven't run solid oak through this saw before and these boards are definitely denser then the plywood I've been pushing through.
              And you've checked the alignment of fence to blade?
                This appears to be a situation that calls for a dedicated rip blade. My two favorite blades are Forrest Woodworker II and Freud series. The Freud LU87R010 24-tooth 10" dedicated Rip Blade is selling for $39.99 on Amazon. The Freud LM74R010 30-tooth 10" glue line rip blade is $69. I think the LM74 would be a good choice for that oak.
                I've been ripping some barn oak and I have to use the Forrest WWII blade. That old oak is hard as can be! The WWII blade goes through it just fine, although I still get a minimum of dark marks. Not really scorching, but there's just a bit of blade mark left on the cut. That oak is the hardest thing I've yet run through the saw, and it is doing a very good job with the WWII blade.
                The blade I have is the Forrest WWII 10"x30-tooth 1/8" kerf. It's running around $95 at Amazon.
                  Try to cut a board 1/4 - 1/2" wider than your final cut. Then reset your saw to the final cut width. If the board still binds there is an alignment problem between the fence and the blade or the fence and the splitter. If the board goes through without binding there is a good chance the wood was pinching the blade.
                  How is your fence set? I have mine set so the back of the fence is a touch wider than the front.
                  Try installing a featherboard ahead of the blade to keep the board against the fence.
                  I take my splitter and blade guard off often. And because I am often less than careful the splitter gets knocked out of alignment. I used to try to realign the splitter with a square but now I loosen the bolts on the splitter and start a board through it. Then I lift the anti-kickback pawls, pull the board back out and tighten the bolts.
                  Tom
                    Originally posted by vasandy View Post
                    this appears to be a situation that calls for a dedicated rip blade. .....
                    +1
                    It could also be that you need to adjust your feed rate a little.
                      That blade and saw combination should cut 3/4" oak without issue. Is the wood dried, flat and straight? Is the blade clean?
                      The R1060 does have Freud's new double side grind which helps give a polished edge. If all is not quite right with the alignment, feedrate, etc, that "burnished" edge can become a "burned" edge with this type of blade. If all else fails, switch to a lower tooth count blade.
                        +1
                        The GlueLine blade from Freud is amazing. What a difference! I got the 30T.
                        Tom's suggestions is also very good. This is what I do myself. I noticed that ripping through the middle of the board give more burn marks then just shaving off an itsy bit.
                        In order to understand recursion, one must first understand recursion.
                          Originally posted by darius View Post
                          +1
                          Note that Freud has a new thin kerf version of the popular LM74R010 30T Glue Line Ripper out...the LM75R010.
                            Thanks all, I'll try all of those suggestions and take a closer look at how the board goes through saw but from what I've investigated thus far the splitter is perfectly aligned, I've been using a featherboard in advance of the blade, I'll have to recheck the alignment of the fence and see how that works. I think I'll also invest in dedicated rip blade or the glue line ripper as I still think that is part of the problem.
                              how high is the blade? when ripping stock, the top of the material, when flat on the table, should not be higher than the mid point of a blade tooth at the highest point of travel. this insures that the blade cuts through the wood, rather like scissors cut through paper. blade height too high, combined with misaligned fence, misaligned splitter and excessive feed rate will almost always result in less than optimum cuts.
