Dust Collection for Weekend Warrior?
  • Dust Collection for Weekend Warrior?
    How important is DC for the average Joe?
    Despite urgent deadlines, I stil get a max of about 4 half days to make chips and dust. Is DC of real health importance - as opposed to visual?
    TIA, Curt
    Curt
    The Jury returned a verdict on this subject. Dust from homeshops can be a hazard to your health. How much of an impact it will have on you depends on many factors, but it boils down to what you want to do. I worked for years without any type of DC. I now wish I had some sort of dust removal system long ago. For a DC that will vent into your shop, you should go with a canister filter. The overhead Air Filtration Units go hand in hand with the DC.
    Support Our Troops!
    www.mnpatriotguard.org
    www.patriotguard.org
      actually it's kinda nice. I'm just plugging in my wetvac to the back of the tools I'm using. the router is causing about 10% of the dust it did before. It's just kinda nice to work with.
        Curt, just blow your nose once after cutting MDF or ply and you'll see that dust collection is a good thing. I don't have a collector yet, but whenever I need to cut stuff like MDF or other woods that have fine dust, I make sure I wear a mask with filters. Hopefully this summer I'll be able to pick up a new collector.
        Was going to get an HF for $149, but am thinking that the Delta may be a better unit and it supposedly comes with 5 micron bags now.
          I have to chime in about a dust collector for us weekend warriors.
          I currently use a shopvac for my dust collection in my basement shop. It satisfies my dust collection needs about 70% of the time, so I'm saving my pennies for a cyclone system and a few runs of metal ductwork for a better dust collection system. I would rather spend a few extra dollars for my health and keeping as much dust out of my house as possible. Plus, I'd love a floor sweep attachment.
          Actually, I might sprinkle a little dust upstairs so my wife will be more persuaded to get the dust collector sooner. [img]smile.gif[/img]
            Curt
            For a real good place for DC information go to these sites........
            http://cnets.net/~eclectic/woodworki...ne/blower.html
            http://talk.woodmagazine.com/default...gory_html___33
            [ 04-14-2003, 09:16 PM: Message edited by: Keystone ]
            Support Our Troops!
              Just finished plumbing in my HF Dust Collector today. The thing works great. It keeps up with my router table,shaper and joiner. These are what makes the most dust in my shop. It is also nice not to have a big pile of sawdust under the table saw after a day of cutting!
              I'm wondering if I can run a line to a overhead collector, kind of like a oven hood, to help with dust from sanding.
              Rob Johnson
              Orange,Ca.
              Just tilt your head a little and it will look straight!
                i have a friend of mine that came up with an ingenious idea for the weekend warrior. i can not fully understand why it works so well but i have seen it work and it works great. he got one of thosebarrels (a bit smaller than a 55 gallon drum) made of cardboard. seals well. put a fitting on it and hooked it up to his shop vac. ran some plastic tube up and branched off to his tools. granted he does not do a lot of volume work, but i was surprised that it worked better than using just the shop vac. perhaps the "bigger vaccum" created by the sealed barrell was the key?
                  I have a TS3612, a Delta RAS, and benchtop jointer. Only the jointer has a chip pickup tube (I connect that to my shop vac.) The rest is various hand tools; router, biscuit joiner, drills, sanders, etc.
                  I'm pretty much at a loss when contemplating DC for this lot. Any thoughts - or just wear a mask?
                  TIA, Curt
                    As a real novice I can only reiterate what I’ve learned through reading. Wood dust is a health problem. It really isn’t the dust that you can see in the air or you blow out your nose that is the health problem. It is the minute particles that get past your natural defenses and wind up in your lungs. Each individual will react differently so there is no “golden tool” or process that is the right answer. Each shop and worker will have somewhat different requirements based on exposure, acceptable risk and tolerance of the individual worker. The basics I’ve learned so far are that you have to capture the dust at its source, especially in a closed system shop, then you need to be able to separate the big stuff from the little stuff and then you need to filter out the sub-micron size particles before returning the air to the workspace. If you worked outside just a fan to move air locally would probably suffice without having to collect, but very few hobby woodworkers fall in that category. Whatever tool you use to cut or shape wood needs dust collection. Some tools produce more and different kinds of chips and dust and thus have different requirements for air movement to handle that particular type of spoil. According to the “experts,” in order to capture the fine dust that is the real dust hazard your collection system needs to flow about 800 CFM at a velocity of about 4000 FPS. Generally you need to feed the filtered air back into your shop. Otherwise, you run into the problems of conditioned air (heat/cool) loss or pulling air from any flame producing appliances (water heater, furnace, etc.) that may be in close proximity to your shop. The general answer to the above DC requirements is a 2 or 3 hp cyclone with pleated filters pulling air through a six inch duct for most major machines and a good shop vac hooked into your smaller tools such as sanders or biscuit joiners. Generally, if you’ve gone to this much effort you’ll add a separate air filtering system too. Now to me, that is a heck of a hefty investment in time, money, and space to be able to enjoy woodworking as a hobby. Are there other solutions? Absolutely, but most are going to be less efficient in terms of collection of the most hazardous dust. Some say beginners should just jump right to the high end system because that is where you will wind up later. I’m more partial to just starting out with a 11/2 or 2 hp standard collector with the right bags, linking straight to a machine as I use it (wonder how long before I get tired of changing hoses) and working up to a central collection system as I need to. I’ve held off getting a 3612 because a contractor style saw just won’t collect dust as well as a cabinet saw. Maybe that will be the next major revision so I can quit working on saw horses outside and set up a real shop.
                      CQ,
                      DANG! Great post to this subject. I'm glad I looked prior to posting, as I was mid way into writting up something simular to you.
                      Again, good job!
                      Support Our Troops!
                        Keystone,
                        Thanks. I wish you had posted also. Comfort in numbers. I had two other points. First, I don't understand that given some of the specs for dust collection why tool manufacturers haven't stepped up to the plate. Why are they continuing to put 4" ports in their machine when they should be 6"? Also it would really be nice if a manufacturer did the right thing and design dust collection into the tool to begin with rather than just modify some existing design. It would certainly be interesting to see what tools would look like if dust collection was job 1. Second is I don't understand why you can't increase the velocity of the air to achieve the same CFM rating. Everything is based on a 3850 rpm motor. What happens if you put a 10,000rpm motor in and drive the air through a 4"port? More of a giant vacuum than a dust collector. I've got a lot more study to do in an area I know nothing about. Great fun being semi-retired.
                          Look at European tools, then. Dust collection isn't "Job 1", but it is a much higher priority than here, due at least partly to their smaller workspaces.
                          a) I think you may be talking about a dust collection system that sounds somewhat like an air raid siren.
                          b) Where do you plan to get said 10K rpm motor?
                          If you want a really top-end dust collection system, they are available. Contact Oneida at the very low end. For a better system, try someone like Torit. Want top of the line? Give Scientific Dust Collectors a call. Expect to pay very big bucks for these good systems, though.
                          Dave
                            CQ
                            Some good points you bring up. I think that the real issue here is $$$$$. How many people are going to shell out say $100 to $150 more for (insert tool) when they can get a simular item for less? If OSHA didn't set min safty laws for companies, how many would worry about a good DC in a wood shop? In the past year I have learnt more about removing dust from a shop than I thought was possible. I had no idea that there was so much research by PRIVATE citizens out there! Do the manyfactures need to step up to the plate? Or do we, the users, need to keep trying to inform other users what the options are? Both is the answer I beleive. There is no reason that equiptment should not have 6" ports on them. My JET DC-1100C came with two 4" ports. Why? Most likly because that is where the industry is at right now. Getting good DC on my contractors saw is a big problem. They just are not made with DC in mind. I've managed, like many others, to decrease teh amount of dust, but I will never get anything better than what I have now with it.
                            There are good systems out on the market. Dave pointed out one of the best. Homeshop owners like myself can not use a cyclone system as I do not have the height that is needed. If I ever do get to build a stand alone shop, you can be sure it will have plenty of overhead room for Dust Removal! Until then I will keep on reading and looking for better ways to remove that stuff from the air.
                            I hope one person reads this thread, goes to those links I provided, and makes up thier mind to do something about the dust in thier shop!
                            Guess I've talked enough...............
                            Support Our Troops!
                              Um, Keystone? Got some good news for you. That black dual 4" wye, pulls right off. The underlying flange is 6". [img]smile.gif[/img]
                              Dave
