Surpintine belt
  • Surpintine belt
    I have a TS24241 (older model) ridge contractor saw the belt is hanging on but has a split in it. Does anyone know where to get this belt. It's 1/2 by around 42-44 long 7 ribs on the belt. I went to the Ridge site and the part number calls for a V Belt
    Thanks Bill
    Re: Surpintine belt
    Hopefully someone with a 2424 will chime in but I believe that the belts used on older saws are standard v-belts and you can probably match it up for width and length at a auto parts house or at other places that sell belts for HVAC equipment.
    If you look close you'll probably find a size and maybe a manufacturer stamped right on the back (wider) side of the belt.
