Planer or Drum sander?
  • Planer or Drum sander?
    Would appreciate an advice.
    If you could afford only one machine: Planer or a Drum Sander, what would it be. Why?
    Thanks a lot.
    I'm lucky enough to be able to afford both.
    How's your patience? An "affordable" (in the thousand buck and under range) drum sander removes stock verrrrry slowly. Like a 1/128" at a shot. So if you want to take stock from rough to smooth-planed, which typically involves a quarter inch total removal, you're looking at a minimum of 32 passes. On my planer, that's four easy passes.
    However, if you use figured woods that tear out on a planer, the drum sander is a lifesaver. That's where mine sees almost all it's use.
    Dave
