TS2400 - Dado blade
  • TS2400 - Dado blade
    Is it taboo to use an adjustable dado set on my Ridgid TS 2400? Just hate to spend the money for a stacked set when I have a nearly new 7' adjustable blade from my previous Rockwell machine. Thanks for your thoughts!
    Re: TS2400 - Dado blade
    No problem using stacked dado set on the TS2400 that I am aware of (I quite frequently use a Freud 8" set on mine)
      TomApple, I think he wants to know if he can use an "adjustable" dado on that machine.
      geosinner101, is it a wobble dado? When you turn the dial do the blades move away from each on one end and then meet back up again on the other?
        Altima...I reread it and I think you are right. My bad.
        But the answer is the same...yes.
        You can use either type of dado set on a TS2400. Many folks use a wobble dado set for saws with smaller horsepower motors (under 1.5 horse) as well as smaller table top saws that have short arbors. You can use a wobble set on the TS2400 as well as 8" stacked sets.
        Tom
          Sorry about the terminology. I was referring to a 'wobbly' dado blade. For the amount of use I make of a dado blade I hesitate to buy a new stacked set. Just wondered if anyone had experience with adjustable blade.
            Cool! I don't own the same saw, so I didn't want to comment on it.
              Just one word of caution - just 'dry' installed the wobble on the shaft of the TS2400. With the outer blade washer off, the shaft nut almost runs out of thread. I know Ridgid likes to have one thread showing with the nut tightened down. Mabey I'll save my money up for a nice stacked dado set. I'm sure my wife will overjoyed with a $$$ purchase.
                The words "wobble" and "table saw" used together should raise a flag! A wobbler will certain cut the channel, although most wobblers leave an arc on the bottom. You can get a decent stacked carbide dado set in the $50 range if you're careful....I think even the $20 HF unit might be a better choice.
                Edit:
                Just stumbled into this deal....your lucky day!
                Edit #2:
                Nuther deal - Oldham 6" for $40 from Rockler.
                Edit #3:
                Nuther nice deal - New Avenger 6" 30T w/5T chippers for $35 plus shipping. Same as the new Oshlun 6".
