R4511 Cut Quality
  • R4511 Cut Quality
    By now everyone but me has one so I assume there's a lot of cutting going on. What should I expect from the R4511, what are people experiencing in terms of cut quality?
    Re: R4511 Cut Quality
    With almost any saw that you buy, including most other manufacturers, the quality of cut dramatically improves when you replace the stock blade. If you're happy with the quality of cut that the OEM blade gives you, you'll be beside yourself after you change it out for a real saw blade. I don't own the 4511 so I can't speak to the quality of its OEM blade but historically Ridgid isn't know for providing the best of quality blades with their saws.
    ------- Henry Ford
      Almost all saws in this class and price range have the capability of delivering an excellent cut. The end performance is mostly determined by proper setup and blade choice, so if the cut's not really good, change something.
        I replaced the Ridgid blade with a Forrest WW II and properly set all the alignments and the saw cuts perfectly!
        Big G
          Big G
          Thanks for the feed back. How many teeth and what kerf is your Forrest? I've got a Freud Fusion 40 tooth with the .126 kerf that I'd like to run in it, at least for crosscuts and plywood.
            That Freud Fusion blade is every bit as good as the Forrest variety. As far as the kerf is concerned, the 4511 should have no trouble spinning the full kerf Fusion when using it for crosscuts and ply.
            ------- Henry Ford
              My Forrest is 40 tooth and full kerf. No problem powering through hardwood with cross-cuts or ripping.
              Big G
