sears excalibur dado #32668
  • sears excalibur dado #32668
    how well does this particular dado perform compared to other adjustable dado's.
    I've been using this dado blade for a couple years.
    The smoothness and flat bottom of the dado are unsurpassed. I haven't seen anything better, not to say there isn't a better one out there. The biggest problem is the price. It is very expensive. If you run dado's on a tablesaw and a radial arm saw then you'll have to dismantle the blade everytime you change tools, per manufacture recommendations. Can be very time consumming the first couple times. I personally haven't tried it on a ras just the tablesaw. I have noticed that it can be a little tricky to get the width exact, just takes a little practice.
    Hope this helps,
      I'm using the Freud stacked Dado and have great results.
      Similar postings I've seen on here are all in favour of the Freud.
      I think it was actually the same price or cheaper than the Sears at HD.
