TS2410 dust
  • TS2410 dust
    I just connected a dry-wet vac to my new portable saw, and although it sucks up most of the debris, there's still a small amount flying about and settling on the shop floor.
    Looking underneath, I see that the bottom half of the blade area is covered by a plastic piece with a connection to the vac hose. It seems to me that if there were a top half that covered the rest of the blade area, most if not all the escaping dust could be drawn out by the vac.
    Otherwise, how do you deal with collecting wayward dust particles?
    Thanks, greg
    Re: TS2410 dust
    Having had a 2400 for several years, I'd recommend a broom. Seriously, it's pretty much impossible to get the whole shooting match sucked up. One thing that I did that helped a bunch was to build one of these. It won't help that much with the part that misses the vacuum intake on the saw, but it will help immensely with keeping your shop vac from getting clogged up. With this separator thingy, almost all of the saw dust gets left in the can.
    Oh, and you'll still need the broom .
    Enjoy that saw. It's a good one.
    De Colores,
    Dow
    Boerne, TX
      Re: TS2410 dust
      Thanks, Phil
      I have broom in hand, and after reading though your plans for a separator lid, I'll be using that too before long.
      Again thanks for the encouragement. It is a fine saw.
        Re: TS2410 dust
        Originally posted by gregjmarquez View Post
        Thanks, Phil
        You're welcome Greg, but they aren't my plans. You'll have to thank Phil for that.
        Good luck,
        Dow
        De Colores,
        Dow
        Boerne, TX
