UHMW Fence question
    Re: UHMW Fence question
    Originally posted by chrisexv6 View Post
    I thought I read somewhere that a slight amount of toe-out of the fence (i.e. its further out from the back of the blade than the front) provides a small amount of extra safety........since the wood is cut to the correct dimension at the front of the blade, any toe out after it would help keep the material free from binding back on the blade. At least thats my understanding.
    Yes, that has been mentioned several times on here. I think that it's discussed in the 4511 availability thread, and probably elsewhere. As I recall, the amount of toe-out recomended was minimal -- I'm thinking 0.005" or so. Fie thousands run-out over a 35" fence isn't much at all -- just enough to keep the board out of the rear of the blade.
    And as for adjusting it, Ive tried to get a little toe out, but once I have some, the set screws are so far in its hard to slide the fence. if I back them out to be able to slide it again, I lose the toe out.....and I also want the screws in more to prevent "slop" when sliding (when the fence is so loose on the track that it gets stuck between the front rail and the front rail bracket).
    Use the two screws in tandem to get the slop out of the fence, and then use them in opposition to adjust the toe-out on the fence. For example, if you're using the fence on the right side of the blade, and want toe-out, you'd loosen the right screw a smidgen and tighten the left screw a smidgen, and then check it. Make a tiny change and check it, and then make another tiny change. I found that a dial indicator works great for this. Harbor Freight has them for about $10, with an adjustable magnetic base for another $10. I used the magnet to stick it down to the miter bar on my incra miter guage and then slid the gauge in the miter slot to compare the front and back ends of the fence.
    De Colores,
    Dow
    Boerne, TX
      I have also read that a tiny amount (less than 1/16 inch) of increased blade-to-fence distance at the back end of the fence is acceptable when ripping solid wood that might be reactive. This is wood where the cut line might spring open a little wider than the kerf due to stresses in the wood that are relieved when the wood is cut. Such wood includes wet wood, figured wood, and wood that has been warped.
      For non-reactive woods, such as plywood, the fence should be exactly parallel to the blade.
      The Europeans have dealt with reactive wood by using a shortened fence, which they can slide so that it extends no more than 1 to 2 inches beyond the front teeth of the saw blade. Now if the cut line springs open beyond the initial cut, there is nothing for the wood to press against to cause kickback or binding problems.
      I plan to build an auxiliary fence that extends only 1-2 inches beyond the front saw teeth that I can easily attach to my main fence when cutting reactive wood. My main fence will stay perfectly parallel to the blade. Has anyone seen plans for a simple and easily installed/removed shortened fence?
        Two thoughts come to mind:
        1. Make your fence faces meet with a lap joint, but that might not be very accurate unless the lap joint is perfect enough to leave a truly flat face.
        2. Make an aux fence that just sits on top of the stock fence (and/or your fence faces), and have the blade side of the fence not run the full length. Should be easy to make, just a box with no bottom and one side is actually a partial side, depending on the distance of the blade from the front of the fence.
          Originally posted by dow View Post
          Yep. Someone, I think it was Ashman? drilled two more holes, but I don't think it's necessary. I see no bowing of the pieces.
          UPDATE: I went out to the shop last night, and I was wrong. There was some deformation in the straightness of the UHMW slabs. I believe this to be a result of my hame-headed approach to tightening bolts, i. e. if tight is good, then REALLY tight must be REALLY good.
          So I removed the bolts and washers, and re-assembled it with just the bolts and lock nuts. Part of the reason for really cranking down on the bolts initially was to make sure that the lock nuts were tight enough. The bolts were a tad too short with the washers, but tne next size bolts would have been too long. When tightening (this time), I only tightened it enough to make sure that nothing would move, not enough to make sure that nothing would EVER move. The deformation is much less, and I'll look at it again tonight to see if it needs additional bolts. What happened, when I tightened it too much is that the ends of the fence slabs pushed out away from the side of the fence.
          indianrider: I didn't get the pictures yet. See paragraph above for reason .
          De Colores,
          Dow
          Boerne, TX
