2412-1 problem with tilt screw
  • 2412-1 problem with tilt screw
    I have the model 2412-1 table saw and stupidly tried to align the blade square with the table without adjusting the 90 degree set screw. Nw when i try to adjust the saw back from 90 the tilt screw pulls out of cradle. My question is how do I fix this? I can't seem to find a way to make the srew stop pulling out of the cradle. Thank you for your help
    Re: 2412-1 problem with tilt screw
    Maybe the tilt nut is stripped out (p/n 826391, item #27 on pg 53, see your manual).
    Also, you'll do better if you don't post in multiple forum areas. With just one post all replies you may get will be in one place.
