Another Router Table Extension question
  • Another Router Table Extension question
    I've seen several post on router table extensions and they've all been some type of wood. (mdf, plywood, etc). But what do people think about a cast iron extension wing? Too heavy on the rails? Woodworking supply near me has one on sale and it's about as cheap as I can make one myself. Link to it is posted below. Would love to hear others thoughts.
    Thanks
    http://www.ptreeusa.com/edirect_cast_iron.htm
    Re: Another Router Table Extension question
    What saw are you attaching it to?
    I wouldnt think it would be too bad on the rails, especially if you are also able to bolt it to the factory saw top/extension wing. Not possible in the case of the 4511 granite top, but pretty easily doable on a cast iron saw (because you can drill holes in the cast iron wing to put bolts thru)
    -Chris
      Sorry, I forgot to put in the post it's the 3650.
      Thanks
        I have an eye out for the Grizzly h7507 Cast Iron Extension. I like the fact that is doesn't have those fence mount slots, the T slot or that oversized Router plate. I have no use for them. I like the fact that it includes two leg supports, I plan on using it to fill the gap on the right side of my TS3650
        It's on back order right now, been waiting since early April.
          Peachtree has their cast iron wing on sale for 149 (100.00 off)
          -Chris
            I purchased a cast iron wing from HF for $50.
              12" or 18"?
              A solid slab or perforated?
              Did it have the cutout to accept a router from underneath?
              that's how much Grizzly is charging me just to ship theirs to me!
                I am not sure if their still selling them. Mine is 12" x 27" with a router cutout, and a rib system underneath for mounting the router.
