Drum Sanding problems
  • Drum Sanding problems
    I was wondering if any of you have experienced similar problems when using your drill press for drum sanding and the abrasive loop begins to raise off of the rubber. Is this corrected with lower DP speeds?
    Any help is greatly appreciated.
    Patrick<br />patrickssmith@cox.net<br />members.cox.net/patrickssmith
    Patrick,
    I had the same problem with the sleeve lifting. I did not try the DP at a slower speed. I found it to be such a PITA that I bought the Delta BOSS. It works much better than the DP and it has dust collection too.
    Bob R
