Squaring BS1400 table?
  • Squaring BS1400 table?
    Welcome a good way to adjust the table so the band saw blade cuts square to the mitre slot?
    Everything has been aligned per manual but blade cuts a bit off 90 degrees horizontally.
    I dont know what type of projects you work on but on my stuff i just dont trust my b/s for critical cuts i use it more for curves etc. but when i have made angle cuts 90/45 etc i end up tweeking my miter guage to get the angle i want, don't know if this helps any bill
      I agree, if I have to cut an angle on the bandsaw I mark the wood, cut free-hand adn smoth the edge with a sanding block. Bandsaw blads tend to wander, going free-hand at least let's you respond by moving the workpiece.
      Just not the right tool for miters.
        Thanks all. Will work accordingly.
