0 Clearance Throat Plate Miter Saw 12900
  • 0 Clearance Throat Plate Miter Saw 12900
    Does anyone know where I can get a zero clearance throat plate for the ridgid miter saw 12900?
    What happened to your throat plate that came with the saw? If you have the original plate on there just loosen the screws and adjust it tight to the blade kerf. If you need a new one you should be able to order one through the Home Depot or a service center in your area.
