BYO Cookies
  • BYO Cookies
    No, these cookies will not satisfy your sweet tooth, but they will help you get some
    extra mileage out of some scraps in the shop. It doesn't matter if you have MDF,
    plywood, or dimensional lumber scraps to work with.
    What you'll need to Build Your Own Cookies:
    Materials:
    (2) Old computer mouse pads -the thicker, spongy type
    used when mice had balls (what'd he say? ) as in
    the pre-laser or optical mouse days.
    (1) Board foot of 3/4" material, can be MDF, ply, or solid wood
    Tools:
    (1) 2-1/2 or 3" hole saw (could be larger if you wish)
    Utility knife or similar cutting tool
    Incidentals:
    Some contact cement or other adhesive, try to use something
    compatible that you already have instead of buying new.
    Use the hole saw and cut 4 disks from your scrap lumber.
    Sand and smooth the edges of both faces. You can use a round over bit to ease
    the edge if you wish but its not necessary.
    Using one of the disks as a cutting guide, lay it over the mouse pad and cut out
    eight matching size disks from the mouse pads. Trim the edges neatly as they will
    show in the finish product. Use a new blade in the utility knife, not the one you
    used last month to hang Sheetrock with.
    Lay the mouse pad disks out on a piece of newspaper or cardboard with the cloth
    side up (same orientation as when used with a mouse). Spray with a aerosol adhesive
    such as 3M™ Super 77 Spray Adhesive or brush on some contact cement and let dry.
    Do the same to ONE side of each of the wood disks.
    Stick a mouse pad to one side of each wood disc and clamp or use a roller to ensure
    full contact adhesion is made.
    Coat the opposite of each wood disc and let dry or wait the required time per the
    manufacturers directions.
    Stick the remaining four mouse pad disks to the freshly coated side of each wood disc
    and clamp or use a roller to ensure full contact is made.
    You're done! Time to enjoy your cookies.
    So just how do you do that you might ask.
    Well, you place 3 or 4 disks on the workbench and your workpiece on top. The mouse
    pad rubber grabs the bench top and also the workpiece to prevent slippage when routing
    or sanding or performing other tasks such as applying finish.
    Re: BYO Cookies
    Knock knock.
    Who's there?
    Rockler.
    Rockler who?
    Rockler's lawyer, you in trouble now.
      Re: BYO Cookies
      Originally posted by BadgerDave View Post
      Knock knock.
      Who's there?
      Rockler.
      Rockler who?
      For using my brain?
      Oh wait, I forgot, I don't have a brain.
      Oh wait, that's the OTHER guy I'm thinking of who voted for the Big O.
        Re: BYO Cookies
        Originally posted by Bob D. View Post
        For using my brain?
        Hold it wait.....Oprah is running for public office?
          Re: BYO Cookies
          I knocked out a set of these this morning in no time at all. The only step I did a little different than what Bob outlined was I used my circle/wheel cutter instead of hole saws. The hole saws would have been faster but I didn't have any that large.
            Re: BYO Cookies
            Knock knock.
            Who's there?
              Re: BYO Cookies
              OH-NO I screwed up as I made mine as rectangles to avoid lawyers banging on my door!
              I hope they will work? I did not know the rules said they must be round!
              I actually used some old black rubber router pad..you know the stuff to keep wood from
              sliding all over the place and some scrap wood.
              I also used gorilla glue. I applied a very thin coat of the glue on the wood and made the rubber pad wet. Then once they met I placed a weight on the entire thing to ensure no lumps from the glue expansion.
              Once all is set I trimmed 1/16" off each side to make them pretty.
              Another option it to get some hockey pucks and glue the rubber on them.
              And as mentioned for the truly lazy folks $12.00 at Rockler's will get you the same results.
              Cactus Man
                Re: BYO Cookies
                Lots of hockey pucks out there, masquerading as politicians.
                  Re: BYO Cookies
                  <-- Lazy and short on time... forked out the twelve bux... Not as yummy as Oreos, but pretty good for setting wood on.
                  Heck, I cannot even find those craptacular old mouse pads except at an occasional garage sale. Not nearly enough to do 8 sides of 3" circles...
                    Re: BYO Cookies
                    WJ, you don't need the thick mouse pads. I made mine with the thin pads, maybe 1/8" thick, that they sell at WalMart for under $3. If you make them 2½" in diameter you can get 8 out of one of the pads. So far, the few times I've used mine they worked just fine.
                      Re: BYO Cookies
                      Call me lazy, got mine at rockler. Honestly I think $12 is a great price for them. If I was going to make them I would have had to buy the mouse pads. But if I had some laying around I would make more, very handy.
                        Re: BYO Cookies
                        BD, changed jobs again, eh?? ;-)
                        Thanks for the tip on cheap pads at Wal-Mart. I rarely go in there. But that made me think of all the thin Dell pads we've probably got laying around somewhere here at work so's I'm going to do some scrounging. ;-)
                          Re: BYO Cookies
                          I happened to be at Walgreen's during lunch today and found the rubberized "thick" mouse pad mats for $1.99 each, or 2 for $3.00.
                          They're a tad under 1/4" thick. Gonna see about some homemade bench "biscuits" this weekend. ;-)
                            Re: BYO Cookies
                            Awww.. Here I am, an IT with computer parts laying around all over and not a mouse pad in sight. I quit using them years and years ago when I switched to optical mice.
                              Re: BYO Cookies
                              also look at padded shelf liners such as this
                              http://www.organize-it-online.com/itm_gripit.html
                              its what the router mats are made out of
