porter cable rebate
  • porter cable rebate
    Just wanted to tell about a $50 rebate by Delta/Porter Cable. You can get the 340k sander for mere dollars from what I have read. The rebate is said to print out when you finish the purchase at the register. You can see the sample rebate at Lowes.com under the rebate section for Delta.
    The only rebate I found on lowes.com is for the delta. The sander 340K is Porter Cable.
    Are you sure about this?
    - Jimmy
      Toolking (in Colorado) shows that there is a rebate available from PC. Check their website.
      Chris Berg
        I went today and bought the 340k sander and the rebate printed out after the receipt. Porter Cable and Delta are somehow connected, I guess one may own the other or something. Look at the
        Lowes website and you will see that the sander is an item# that is listed under the Delta rebate.
          see: http://www.bt3central.com/forum/topic.asp?TOPIC_ID=4990
          Pritch-
