Freud SD608 on TS3650
  • Freud SD608 on TS3650
    Has anyone used the Freud SD608 Dial-a-width Dado on the TS3650? When I put the inside left cutter blade on the arbor, I noticed that the 3 nuts that hold the bushing to the blade rub against the arbor assembly. There doesn't seem to be a big enough gap around the arbor bolt for the nuts to spin around freely. Freud suggested using some type of spacer, but to check with Ridgid first, but that would limit the number of chipper blades that would fit properly on the arbor and reduce the available width of the cut. Ridgid hadn't heard of this problem before so they weren't much help either. Any suggestions?
