3650 blade to fence alignment
  • 3650 blade to fence alignment
    I'm not seeing the forest for the trees here. I added a sacaficial wooden fence to my rip fence and now the dang material binds on the outfeed side of the blade. It *really* hangs on the splitter and I coln't make a satisfactory adjustment so I removed it. I have measured the tooth to fence distance (using the same tooth) at the infeed and outfeed sides but something isn't right. I assumed that the wood was an even thickness but maybe I'd better pull it and run it through the planer. Any other suggestions?
    TIA,
    Chiz
    Later,
    Chiz
    If you have one, I'd run the piece through a planer instead of using the jointer. If you don't own a planer, you might try making your sacrificial fence out of MDF.
    You might also try waxing the sacrificial fence.
    [ 05-22-2005, 10:28 PM: Message edited by: BadgerDave ]
