Removing springs from Craftsman router
  • Removing springs from Craftsman router
    Hey everyone,
    I've got a Craftsman double base router kit -- I believe it's this one: http://www.sears.ca/gp/product/B000V...deid=396992011
    I've recently built my own router table and would like to use this router in its plunge configuration for the table but I don't know how to remove the springs from it; all the discussions I've seen are about removing springs from dedicated plunge routers (which I'd eventually like to get for my table, but for the time being, I must use this router).
    I've posed this question to Sears, but I'm not sure what they're turn-around time is (or if they'll answer a question like this) so I figured I'd pose it here, as well.
    Any help would be greatly appreciated!
    Thanks,
    --Jeff
    Re: Removing springs from Craftsman router
    I haven't seen this router in person, so I can't help with taking the springs out, but I have a double base Bosch system, and just mounted the fixed base to my router table. Then I just change out the motor for use with the plunge base when using the router handheld.
      I went online to sears parts and looked up my model. The exploded view diagrams should give you a good idea how to remove the springs
        I was going to use the fixed base but it actually doesn't fit due to very low handles :S
        I'm using the Lee Valley 9" round plate which mounts from under the table (http://www.leevalley.com/wood/page.a...=1,43000,51208) and routers with low handles require extra work to fit; I think, after doing the mods, I'd be lacking a decent ledge for the support.
        I'm also planning on trying to cannibalize a spreader clamp to use as a router lift linked to a foot pedal; I'll post details if I'm able to get it working.
        Anyway; I figured it out. Had to remove a plastic cap on the top of the router base and remove one of those retainer washer-like things where you need to spread it apart to remove it. For those of us who don't have the special tools for this, I found the following worked pretty well:
        - grab two jewelery screw drivers which thin enough shafts to fit into the holes of the retainer washer (I don't know what these are actually called...?)
        - put them into the holes, and grab some scrap wood (I used left-over shims) to wedge between the screw driver handles such that they're splayed out at about 45 degrees.
        - compress the end of the screw drivers using the wood as a pivot point which will expand the retainer clip, and then lift up
        Essentially I just made a make-shift spreader/plier type tool. It's a pretty obvious solution, but figured I'd mention it in case it might help someone out.
        Cheers,
        Jeff
          When you do get a new router you should loot at the Porter-Cable kits they are great. I have been using mine for two yrs and it's the best one I have ever owned.
            Would it work with the fixed base if you just removed the handles?
            ------- Henry Ford
              Likely, yes; one of the nice advantages of the 9" Lee Valley plate, though, is that the router is easily removable from the bottom and can then be used free-hand without any need to remove the plate or anything, so I wanted to keep that versatility.
              Although... in retrospect, now that I've removed the springs, the plunge mechanism isn't overly useful after I remove the router from the table, and would require additional work as well, so I guess my point is moot
              I usually use the fixed base free-hand, it seems, so I guess I was just trying to keep that base in tact as much as possible.
              Cheers,
              --Jeff
                Cheers,
                Jeff
                I believe the part you encountered is called a snap ring and can be removed and reinstalled using these snap ring pliers.
                  I can't count the number of times I wished I had one of those pliers. They really are a frustration saver when you need one. They were something I always meant to buy but never seemed to remember to actually purchase. While at the store one day I finally remembered to buy them. A very handy $4 tool.
                  ------- Henry Ford
                    Yes, Sir!
