Mortising Chisel and Bit
  • Mortising Chisel and Bit
    I went to Home Depot this morning to purchase the 3/8's Mortising Chisel and Bit set and read on the carton it was to be used with the Mortising Attachment.
    I wanted to use this on my new Ridgid Drill Press.
    Do I need the attachment too? HD had a Delta attachment, could not find a Ridgid.
    Any help would be appreciated.
    use a ridgid attitment.
    Andy B.
      B,
      You need the AC6005 Mortising Kit. It should be available at HD or you can purchase it online at www.ridgidparts.com
      Jake
        Thanks Jake:
        Do you know if this is a common accessory at Home Depot? Also, does the kit come with any bits or if not are these bits universal?
          If HD stocks the chisels they should have the kit, otherwise it would be like having the chicken before the egg.
          Jake
          [ 01-17-2002: Message edited by: JSchnarre ]
